Pat---There are only 3 or 4 pieces that are different to make the engine the cdi version. I will try zipping the individual pieces up and emailing them to you.---BrianBrian,
Any way that I can obtain the SW models for the CDI version?
Thanks,
Pat H
Maybe somebody can check my math----This engine seems to have astonishing compression, to the point where I can barely turn it over by hand. I just ran a quick and dirty calculation, and it appears that the compression ratio is about 12.5:1---Maybe I've made a mistake. If not, that's an uncommonly high compression ratio for a hit and miss engine.
I am assuming the wheels allow the cart to roll back and forth a bit to dampen the vibrations from the engine.
http://s307.photobucket.com/user/Br...005/ENGINEBOXFINISHED004_zpsd0b967e3.jpg.html
Hi Brian-- It looks good
as for the vibration the Wheel has nothing to do with the dampening
of the vibration.
the weight does it hall same thing when you bolt it to your workbench
the clamp does not damper the vibration but the weight of the bench does.
I think that if you mount the motor on 4 valve spring you will be able do cancel the vibration using different tension on the spring
I'm back to the build tomorrow check for pictures soon
