Rupnow i.c. Engine with governor
Well there!! That's better.--I was getting sick of looking at that gaping hole in the top of the water reservoir. Now its time to cut the grass and wash the hotrod to get ready for cruise night.
I am rapidly running out of fun, easy, no-brainer stuff to build. Although the hokey crankshaft seems a bit weird at first, it seems to be easy to make and doesn't appear to have any more run out than the "normal" crankshafts I have built on all my other engines. I really don't want to invest a lot more time in the governor until I convince myself that the engine runs okay in "normal 4 cycle engine" mode. I am going to use the same carb setup that I used on my last hit and miss engine. I guess I will start tomorrow on the rocker arm and the rather strange shaped piece that supports it. Monday I will go buy a set of points and build the support block for them and make an ignition cam. Nobody has asked me yet, but the small gear is not held to the crankshaft by magic---Its cross drilled and anchored with a 1/16" split pin thru it and the crankshaft. Looking at it in hindsight, I had lots of room on either side of the small gear for a hub and setscrews, but even I get locked into paradigms.--That gear worked just fine on the last hit and miss engine I built, which also had a 3/8" crankshaft, so I'll use the same again.--Yeah, right!!! The only problem with a gear this size is that the root diameter of the gear doesn't really leave enough meat for a proper hub and keyway or set screws, and if I increase the size of this gear, then I have to increase the size of the cam gear, and yada yada yada!!! It'll be fine!! Notice how I am skirting around the issue of valve cages and valves.---Its like having a tooth extracted---You put it off for as long as you can---
I'm really enjoying watching this thread Brian, that engines coming along fantastic mate! Very impressive.
cheers, Ian
And the only machining that's going to happen here today, is the "Rocker Arm Mount". I don't think "Tricky Bugga" would be an overstatement!!! I did have a last minute change of heart and made the pivot hole .093" diameter instead of the .125 the drawing originally called for. I will fix up the drawings later today or tomorrow.
NOT GOING TO MACHINE ANYMORE TODAY--Yeah, I know, Liar Liar Pants on fire!!! Once I got the rocker arm mount machined, I just couldn't help myself. I had to make the rocker arm. And once it was done, how could I live without machining a pushrod. I'm going out on the back deck and drink beer now---
Something I noticed during assembly of the pushrod this afternoon---I was quite emphatic about the overall width of the pushrod with the bearing installed not exceed .244".-I put a big note to that effect on the drawing. My reasoning was that since the cam is only .250" thick, I needed clearance between the face of the bearing and the inner face of the gear. BIG HEADSLAP FOR ME--- If I'm a bit crowded for room, I can always put a .020" or .030" spacer between the cam and the sideframe. This would require a slight counterbore in the outward face of the gear if using a 1/2" shoulderbolt to hold the cam gear in place, but there is lots of room. See, its the finished position of the cam gear that determined where the crankshaft gear gets placed.
Well Brian, I've been lurking around for the last few years watching you and others create superb models, about time I started as well, got room for another aussie for the i.c build? Andrew
Andrew, I would certainly welcome you to the build. This has proven to be a most interesting engine, and I am closing in on the home stretch of mine. I supposedly have 5 other people around the world who are building this engine with me, but I'm not seeing too many posts from them. Have you built an i.c. engine before?---Brian
This morning I went and bought the ignition points and made the ignition cam and the bracket to install them on the engine . Its very "busy" in that area, but everything does fit. It looks like perhaps the carburetor is up next---
Someone emailed me and asked why I didn't show more "set-up" shots rather than just finished parts. When I first started posting 5 years ago, I used to show a lot of "set-up" shots, because everything was new to me and a proper set up was pretty exciting stuff. Now after 5 years of engine building, the set-ups have became such a normal part of the entire machining process that I don't generally do "set-up" shots anymore. At any rate---Here is a set up shot, showing the carb body in the 4 jaw on my lathe. I actually machined the 5/16" diameter using the cut off tool so I would have a good square shoulder where the round transitions into the square section. I have threaded the round part 5/16"-24 and just drilled a .210" hole full length of the part. I will finish it up tomorrow.
Brian, would you please be so kind as to post a PDF of the points cam. Thank you;
Greg
