I agree with the physics of emitting radiation, but not always in the infra-red, which is why an efficient blue flame and similar yellow flame feel different when the human body detects the radiation. Wavelength or frequency makes a big difference I think?
It's more than a little counter-intuitive, but IR (Infra Red) radiation carriers the least amount of energy. Higher frequencies of light, such as Blue and UV carry the most energy. For reasons I don't understand, our bodies don't feel UV light, which is why you can get a nasty sunburn on a cloudy day and not feel it until that evening when your skin turns bright red from cellular damage. Our bodies can feel the lower light frequencies of IR & Red but not the higher frequencies of Blue & UV. So we humans perceive IR & Red heat objects to be hotter,...but that's just our senses tricking us.
Because you are using freon (whatever) instead of water, with its temperature limitation, I respect your plan for using the hot exhaust gas, as by adding extra air you can effectively cool the exhaust to control temperature . ... I am sure you will have done some heat-flow sums to get a good idea for the heat absorption capacity of all those coils to the gas ?
I've done a few calculations using the Conductive Heat Transfer Calculator I found in The Engineering Toolbox.
I'm aware that determining heat transfer through the tubing wall is only one step,...one must also determine heat transfer into the liquid or gas inside the tube. But for now, looking at only the required surface area of the tube and using the following inputs for the above online calculator:
200 W/(mK) thermal conductivity of the Aluminum tube's wall.
0.006 sqr meters (9.3 sqr inchs) total wall surface area.
500 C exhaust gas temperature (I'm assuming temperature drops from the much higher exhaust gas temp.)
184 C water (Freon) temp inside the tube
0.00071 meters Wall thickness.
Given the above inputs, the calculator tells me that I can transfer 534 kW through just 9.3 sqr inchs of tube surface. At first glance, that answer seems wildly impossible, but several other online calculators yield similar results, so for now, I will accept this answer as accurate. Your thoughts?
I have not yet determined exactly how to calculate heat transfer between the inner tube wall and the working fluid flowing through the tube. Still looking for an online calculator for this little problem.
Got any suggestions?
The only suggestion I can make is that the coils are spaced by approx 1 tube diameter, which is a "convenient" standard used in water tube boilers for a number of reasons, not the least being gas flow.
Otherwise, your burner-boiler design is a bit distant from my expertise.
Just a thought... from the red-hot end plate, where is all that heat going to be collected, as there isn't much boiler where that red-heat is shining? Is the end plate (RH end of drawing), where it looks like the hot vapour is exiting the boiler, heated by the radiant heat from the burner end plate? This may be the superheater you mention?
Good assumption Steamchick
I posted the left photo in my Ambitious ORC Turbine thread some months back; it shows the 8 steam tubes feeding into the turbine's steam chest. The right photo shows what I jokingly refer to as my steam tube spider, because it has 8 "legs"; it's mounted inside the boiler with the black side facing the burner exhaust red hot end plate, where it's black surface will absorb lots of radiant heat. The spider will act as the final super heat area before the steam leaves the boiler. The non-boiler side of the spider contains a thermal sensor which will send temperature data to the micro-controller. BTW, for those whom are curious, the black coating on the spider is Type 3 hard coat anodize, which is essentially a 2 mil thick electroplating of Aluminum Oxide; it's thermal conductivity is horrible (30W/mK) but it's resistance to corrosion in high heat conditions is just amazing. My plan is to hard coat all the aluminum tubes in the boiler to protect the tubes from the corrosive affects of exhaust gasses on bare aluminum; the coating will slightly decrease thermal conduction across the tube walls, meaning I will need more tubing, but avoiding corrosion is well worth the additional tube length.
None of the tubes are as yet welded in place, and the tubes in the right photo aren't even the correct shape,...I placed the tubes in their correct location on the spider body just to take the photo and give readers an idea of what it will look like. The final tubes will form 8 interlaced coils looking a lot like interlaced coil springs, except more widely spaced to allow for good air flow. Each "spider leg" (right photo) will be 18" long and at it's end will be welded into a "Y" junction with another "leg" thereby reducing the leg count down to 4. At the moment, the 18" length is 100% SWAG !! (Silly Wild Arss Guess)
![Boiler Turbine Connection sml.jpg Boiler Turbine Connection sml.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/93/93299-59976099ae5c80b50033f9f22a37d180.jpg)
![Boiler Spider.jpg Boiler Spider.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/93/93300-c97c98fd2e9c40d442cda017b99b7687.jpg)
