Hi Toymaker. I understand why you are choosing R123 as a working fluid. The Entropy, Enthalpy and other data is included in the data sheet.
I have commitments all today, and most of the weekend, so I'll have a look at the sums next week for you. The simple aim is to produce an estimate of the surface area of coils you need to exceed to be sure you are getting enough heat from the burner exhaust gas. Your 9300sq.in. is probably OK, but I'll see what the numbers give.
As you are studying the thermodynamics, have you reached the "boiler" calculations yet? Or have you manually worked the calculations by hand (calculator, log tables, etc.) to figure out where you lost your factor of 1000? Maybe a K in kw? Or kg or similar?
The YouTube course I'm watching is 52 separate episodes and is a general Thermodynamics course, not specifically focused on boilers,...I hope some of the episodes cover monotube boilers, but I don't know if they will.
However, the fourth video is an Intro to Convection and covers the main equation for determining heat transfer from a moving fluid (like combustion gases) through a solid surface such as the roof on a house or the walls of a water tube boiler.
Using the Heat Rate formula: q = hA(Ts – Ti) Note that Ts and Ti can be in either order, it's the Delta (or the difference) between the two Temperatures that is important.
where:
q is Heat Rate : Thermal energy transfer per unit time measured in Watts
h is the Convection heat transfer coefficient
A is area in square meters
Ts is temperature of solid surface in degrees C
Ti is temperature of the bulk fluid (combustion gases)
Assume the monotube is copper, desired power output is 300 Hp, and combustion gases 600 C.
Solving for A, ( surface area of the monotube):
A = q / h(Ts – Ti)
A = 223000 W / (400 W /
= 1.33 square meters = 2,061 square inches
However: there are several problems with this overly simplistic equation. The equation only looks at heat transfer from the combustion gases into the tube wall, and not into the fluid inside the tube. We must also assume the combustion gases are 600 degrees throughout the entire boiler, and we know that isn't accurate; gases close to the burner exhaust will be much hotter, likely above 900 degrees, while other area inside the boiler closer to the exit will be much cooler as the exhaust gases transfer their heat into the tubes.
IMHO, To get a truly accurate idea of tubing surface area needed will require computer software capable of CFD (Computational Fluid Dynamics)
