When I first began considering how to design my water tube boiler I made the incorrect assumption that the working fluid would quickly begin to boil, creating vapor and greatly expanding; I assumed, incorrectly, the boiling would take place within the first few meters of boiler tubing. This false belief is why I thought it a good idea to increase the tube volume by splitting a single tube into two parallel tubes, thereby doubling the area inside the tubing.
However, I neglected to take into account that the feed pump would be delivering the working fluid into the boiler tubing at 500+ psi, and at that pressure, the R123 would not boil until it reached 180C. The pressure-enthalpy chart clearly shows the working fluid wont be changing into a vapor until it's very nearly ready to exit the boiler and enter the turbine.
This means that a single monotube is the better approach.
Studying the diagram, it's clear that if I heat the fluid to 190C (blue lines at #3), instead of 180C as planned (green line from #3 down to #4), then the vapor in the turbine will remain a vapor as it looses heat passing through the turbine blades. The green line from #3 down to #4 falls within the saturated vapor region where most, but not all, of the working fluid is a vapor, but a few droplets of liquid could be present; liquid droplets erode turbine blades so liquids suspended in vapor must be avoided.
BTW, Steamchick, I'm starting to warm up to the value of using pressure-enthalpy vs temperature-entropy diagrams. It's obvious in the P-Enthalpy diagram below that R123 remains in the liquid phase the majority of time it's being heated, from #1 to #2. This important aspect isn't at all clear in a Temperature-Entropy diagram.
![1662381034910.png 1662381034910.png](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/93/93624-1662381034910.png)
