It took me a while to figure out how to light an oil burner.
I could not find any instructions for this.
Here is a video of me lighting my siphon-nozzle burner, running on diesel, and this is the burner I use to melt gray iron.
I put a paper towel with a little diesel on it inside the furnace, light the paper towel, and then turn on the compressed air and fuel simultaneously using ball valves.
I always put two layers of cardboard under the crucible to prevent it from sticking to the plinth, and in this video, I used cardboard that was too large, and it blocked the airflow to the point where the burner flamed out when I started it.
A flameout is not a big deal, but you should immediately turn off the compressed air and fuel ball valves, as I did, and then start over again.
I use a Toro variable speed leaf blower, which operates at its lowest speed for 2.6 gal/hr diesel.
I have a PVC dump valve in my combustion air line, so that I can start the burner, and then slowly ramp up the combustion air, so as to no blow out the burner.
I have a needle valve upstream of the fuel ball valve, and the needle valve is preset to the 2.6 gal/hr fuel flow rate.
I never change the needle valve setting after I calibrate it to 2.6 gal/hr.
Once the burner has started, the dump valve is fully closed, delivering all of the air that the Toro leaf blower produces on its lowest speed into the furnace.
This burner uses the Delvan nominal 1 gal/hr nozzle, operating at 2.6 gal/hr via a fuel tank pressurized at 10 psi.
I use a compressed air pressure somewhere between 15 and 25 psi.
If you are new to burners, you should wear a full face mask when starting a burner.
In the video below, after years of operating oil burners, I am comfortable enough with starting this burner with safety glasses only, since I know exactly what it will do, and exactly how it operates.
When in doubt, wear a full face shield (better safe than sorry).
