It should be noted (perhaps I mentioned it before) that pouring iron cannot be a casual thing like pouring aluminum.
Aluminum melts at a low temperature, and can be melted in almost any container (steel containers/crucibles will degrade over time, but they can be learned if you are trying to learn to melt aluminum).
Almost any burner operating at almost any setting will melt aluminum.
Aluminum melts are very easy and is very forgiving of misadjustment of things.
Iron does not melt easily, and the burner output and combustion air setting has to be perfect, at 2.7 gal per hour, or approximately that. Any variance from the exact burner setting will prevent most iron from melting, or prevent the iron from reaching a good pour temperature, which is about 2,500 F.
The saying is "Iron takes no prisoners", and the sightest contact with molten iron on the skin causes immediate 3rd degree burns.
If you try melting iron, don't take a casual approach, since that most likely will not work, and you most likely will get burned.
Assume it is like taking a hike to the top of Mount Everest.
Its relatively easy to get to the top of Everest with the right equipment, training, preparation, etc.
Without the right setup, equipment and knowledge, climbing Everest will be a deadly affair.
