- Jan 24, 2009
- 554
- 124
Now put them in the oven at 600*F (most will go that high) for about an hour.
Pete
Pete
Probably another obvious question, but I've made this engine with a cross plane crank and each journal is 90 degrees apart. The cams I've made will have flats machined onto a shaft and held in place with a set screw. Are these flats machined at 45 degrees apart or 90?
With regards to cylinder banks, are you referring to the V angle? If so I can't remember specifically what it is as I had to work it out with what materials I had on hand. Does this angle play a part in timing?
The crank throws are 90 degrees apart.
Timing I haven't worked out yet.
Will be a glow engine for starters. When I've got my head around the ignition side of things I'll convert it.
after going back an rereading i see that it is made in with 4 90 deg throws.... that still isnt too bad.... been down that road.... brings it up to only 16 poss combos
