Thanks Jason. Good points. I was in Dearborn a few times during the 1990s, but didn't think I should need to know the details of the quadricycle, though with hindsight... (!?). Thanks for the explanation of the valve gear. It was about what I had guessed... but I didn't know it was to space the firing timing of the 4-stroke engine. Makes good sense.
The "throwback" as you put it, was simply a way to manage the "unknown" side forces by the use of a crosshead and guide. This was at the earliest stages of infernal combustion engines, so reliable "steam" technology was the only known working solution to many problems of geometry and materials commonly in use at the time. Although we commonly use Aluminium today, it was an expensive and rare metal until after WW2 (1940s), so that is certainly a deviation on this model. But looks good anyhow...
I have worked on many pre-1940s old car engines with cast iron pistons. Not a throwback, but the cost-effective technology of the day. Similarly, I machined 10inch diameter crosshead castings into finished parts during the 1960s for Broome-Wade air compressors, that were still available "new". So crossheads should be expected from the 1890s, not a "throwback".
Although some compact marine (Naval) steam engines had con-rods projecting inside the pistons. - c 1870s? I think? - As far as I understand the common arrangement was still to have a crosshead, that H. Ford neatly fitted onto the end of his cylinders. So I think it is good to model this bit of the design correctly. Many of the large industrial Gas engines of the turn of the century used crossheads as well.
But not all? - I am not sure:
Maybe H.F. was simply staying with the "most reliable" design in current use for this part, so he could concentrate on making other parts of his first Automobile that were new and unique?
An interesting viewpoint anyway.
Thanks,
![1735897774713.png 1735897774713.png](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/117/117000-1735897774713.png)
![1735897604448.png 1735897604448.png](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/116/116999-1735897604448.png)
![1735896849897.png 1735896849897.png](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/116/116996-1735896849897.png)
![1735896884959.png 1735896884959.png](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/116/116997-1735896884959.png)
![1735897002651.png 1735897002651.png](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/116/116998-1735897002651.png)
Thanks,
