- Jun 24, 2010
- 2,455
- 974
Google your model number carb & should get some hits. The fundamentals should be available on-line through OS parts schematic breakdowns (in terms of identifying which screw does what).
There are general procedures along these lines
http://www.osengines.com/faq/product-faq.html#q16
You will probably find both good info & maybe what I'd loosely call mis-information where people are having issues or solving problems that are aircraft orientated & maybe not quite applicable to your specific application.
I think a new/unknown engine with its own teething pains is an additional consideration to the carb itself, even assuming its set up 100% correct. But I'd say try & get a mid-range rpm running to begin with, then worry about idling & top end as a secondary goal. Generally if the AF mix is out of whack in the mid/high range, it only makes solving low/idle running even more challenging. Double check for air leaks like on the carb throat o-ring/gasket & fuel line leaks like on inlet nipple.
I also have a feeling 'starting' is a ritual itself with these glow/methanol jobbies. I've ran so many RC engines that were set up perfect. But that was with the classic electric starter. Now if I decided to hand flip the exact same beast, it seems to require more effort & tries to get it going. Then its so tempting to diddling needle valve & adjusting things trying to find a sweet spot. I'm not saying go to starter right away but keep in mind if required. Even something moderate like a low rpm cordless drill will help, especially if its being difficult. Just beware any hint of hydro-locking when using starter. Remove plugs, drain every bit of methanol, resume operations.
Sorry, cant speak to your 4-plug (reduced cylinder) trial with any experience. You're miles ahead of me!
