V8 nitro engine
The effect on cam lobe seperation
widening lobe separation will do the following
Raise Torque to Higher RPM
Reduces Maximum Torque
Broadens Power Band
Reduce Maximum Cylinder Pressure
Decrease Chance of Engine Knock
Decrease Cranking Compression
Decrease Effective Compression
Idle Vacuum is Increased
Idle Quality Improves
Open Valve-Overlap Decreases
Closed Valve-Overlap Decreases
Natural EGR Effect is Reduced
Increases Piston-to-Valve Clearance
If you want a good running V8 I would suggest about 280 degrees open
with 110 degrees lobe separation. Give you a nice warm sounding engine
with a good idle under 1000 RPM. Sound about like this.
[ame]https://www.youtube.com/watch?v=FnbwsLysqGk[/ame]
That is just an amazing looking and sounding engine! Thank you for your help and figures. With those figures, are the exhaust and intake lobes the same(280 degrees open)?
Are the valves opening at any specific point?
Thank you again Steve.
Cam timing in the V8
Brilliant. Thank you Steve.
Made the rocker arms today. Started with some steel bar, cut them, machined to shape, filed the contact tip by hand then case hardened it. I will nickel plate them when I get a chance. Happy with my progress.
Prior posts on timing with some methanol examples. But I think you have some better qualified input already. Another thing I've noticed that sometimes gets glossed over in cam discussions is the Rocker ratio + Pushrod & Lifter geometry possibly acting at 3D angles + any clearance gaps between lifters etc.... can all affect end result timing in terms of valve physically opening & closing. I'm not sure by how much or if it makes a hill of beans difference, but just mentioning FWIW.
http://www.homemodelenginemachinist.com/showthread.php?t=21808
http://www.homemodelenginemachinist.com/showthread.php?t=17093
Thanks Petertha. I have thought all about those things you've listed and it does worry me if I don't do thinks correctly. But I have tried to keep things as simple as possible. The rocker ratio, which I'll be honest, I don't understand, but assume it is in reference to where the pivot point is in the middle of the rocker? I've kept this in the centre so I'm assuming this gives me a 1:1 ratio.
I think I jumbled too many things in one sentence. The rocker ratio I think is just a teeter-totter. If the valve side length = pushrod side length then resultant valve lift = pushrod displacement. If the rocker axle is not centered, for example pushrod side is 0.8" and valve side is 0.7", then the valve lift will be reduced 0.7/0.8 (87.5%) of pushrod displacement. So this doesn't affect intake/exhaust timing, just lift.
But where this gets funky is how the cam throw acts through the pushrod/tappet assembly onto the rocker because typically these components don't line up all neat & perpendicular and sliding faces & sockets etc. There could well be some 3d geometry acting through the assembly as a whole. So just designing a cam profile to yield open/close duration (in isolation of the other components) may not yield exactly the same open/close timing at the valve itself. Again, whether this is small or large or worth fretting about is another subject. Hope that clarifies what I was trying to say.
That makes sense Petertha.
Thanks for the clarification.
More progress. Machined the cams out tool steel. Went with the 280 degree intake and exhaust duration with 110 degrees lobe separation. Will heat treat them when I've finished cleaning them up. What is the preferred liquid to use for quenching this type of steel? I believe it's oil hardened silver steel.
