Yes thomo, a complete plan set will cost $25 Canadian funds.
The length of the piece is determined by the depth available in the three jaw chuck which is attached to my rotary table.
But did you die? If not, then how would you know if you had fun?Today was not a good day. I fought the cams and the cams won. The cutting tool slipped in the holder. The stock slipped in the chuck.
I was overwhelmed by a hoard of zombies. I was bitten by a rabid bat. I was stung by a murder hornet. My day has turned to crap. Perhaps a different approach to making cams will be investigated.
I have always just centered the cam on the rotary table and used an end mill. Move the spindle .302 radius plus 1/2 the cutter dia and turned the table through a 240° arc. (360-120) Then moved the mill table .346X and -.200Y plus half the cutter dia and start cutting at where the 240° arc stopped. Obviously done is steps, not all in one cut.Today was not a good day. I fought the cams and the cams won. The cutting tool slipped in the holder. The stock slipped in the chuck.
