Something is not right, and right now I don't know what. I can not get this beast to fire. The valve timing is good, the ignition timing is good, and the head gasket is good. This morning I even resorted to a bit of fuel poured down the sparkplug hole, and it still wouldn't fire. The valves are sealing like they are supposed to. About the only thing left to check is the Viton ring on the piston, and I don't think it is damaged, but it's worth checking. The electronic ignition from Roy Sholl is giving a good spark at the right time. (this electronic ignition was used before about 10 years ago one one of my horizontal engines). I used the electronic ignition on this engine because there really is no good place to set up a pair of ignition points for my old school points ignition. Of course, since the engine is my design, I can always modify it to make room for a cam and a set of points if I have to. I have been looking at YouTube today, and I like the trembler coil set-up as used on model T Fords. It appears that very little is required to convert a conventional 12 volt coil, and the continuous spark is just awesome. Thinking---Thinking---
