Gordon---That sounds very interesting. I will have to try that method.----Brian
First, you poke a hole in one end of the egg, then ...Awake---You're teaching your granny to suck eggs. The axis of the workpiece is vertical.
Geez, Brian, We all know you are good llooking but it's the rich women that DON'T know you are. You need to find one and SHE will pay for it, I'm sure.Crankshaft is in, dummy shaft is out. Crankshaft turns easily, nothing crashes. This is always a milestone event for me, because there are so many tolerances that can add up to cause some kind of internal interference with the crankshaft. I'm not going to put keyways in until I'm absolutely sure what I'm doing for flywheels. If I was rich instead of good looking, I'd buy a pair of flywheels, but at $35 each American, plus the difference in our dollars, plus tax, plus shipping, I'd be paying $100 for two flywheels.
Joe Pie also has a vid on this.Brian, do you know of a tutorial on making a crankshaft that way?
I've seen bits and pieces but not enough to know how start from a steel bar and end up with a usable part.
Bob---Here's your tutorial.---Brian
https://www.homemodelenginemachinis...om-1144-stress-proof-steel.33366/#post-363837
