kcmillin said:I really like your method with the spark plug wires. :bow: Very Clean and neat looking. What are you using for the plug end?
Kel
stevehuckss396 said:I would like to find something to use as a boot but I might Have to make something.
kcmillin said:I am using R/C fuel tubing with heat shrink tubing over that on my TI4. It makes a nice looking boot, however the boot ends up much larger than the wire, due to the thick walled tubing, but it does hold nice and tight to the 1/8" brass plug contact.
Is the cap you are talking about made of brass? Perhaps you could use only heat shrink tubing, but what type of friction device are you using to hold the wire to the plug?
Kel
aermotor8 said:steve, bob shores used to make spark plug boots. i think he used a liquid rubber of some kind and he poured it in to a split mold.
just a thought, some one else might know what all is involved in this procedure.
as always you produce some very amazing work :bow: , i like following along.
chuck
jpeter said:Regarding the boot mold, geeze and just when I think I've got a unique idea.
The proper diaelectric material can never be an affront to ones manliness. ;Dstevehuckss396 said:Thats the easy part. Finding the right stuff to pour into it is the hard part. One fellow at the meeting said he had enough to make all the boots we need for our engines. PINK! I don't know about you but I non't want pink boots.
Lakc said:I think good old Mopar black RTV would work.
stevehuckss396 said:Jim tried it. Wouldn't set up in the mold. Every spark boot i have ever owned was black. Something black has gotta work
The 8 year old tubes in my toolbox probably wont, but if you allow some air to reach different parts of the mold with stringers, it should. One major problem with any RTV is its crappy short shelf life.stevehuckss396 said:Jim tried it. Wouldn't set up in the mold. Every spark boot i have ever owned was black. Something black has gotta work
