I have a question now, that won't really have any effect on the way things get built, but may ultimately effect the way things get assembled. As you can see in this section view, the slot milled into the side of the crankcase to admit air/fuel mix is on an angle. If the engine rotates in the direction I have shown with the black arrow, it seems to me that there will be a pressure wave built up in front of the revolving crankshaft that will try to force incoming air fuel mix back out of the crankcase. Conversely, if the rotation is opposite to what I show, then there should be an area of low pressure behind the revolving crankshaft that will actually help to pull air/fuel mix into the crankcase. Since the engine is symmetrical about the centerline, I can choose which side I put the flywheel on and thus determine the direction of rotation. I like my engines to revolve clockwise when viewed from the flywheel side, because I use a starter spud in my variable speed drill to start my engines, which engages with a slotted hub attached to the flywheel. If the engine revolves counter-clockwise, then the drill chuck will loosen off. Is what I'm saying valid, or am I over-thinking things??
