..done carefully the laps won't ever get way out of shape but they still will wear a bit..
Pete
My experience was they can wear 'quite a bit'. But I'm sure that's a function of lapping grit, liner material, lapping alloy, removal amount... etc. & everyone's mileage may vary. For example on my cast iron liner (harder material) I was progressively pinching in the screw, lapping away. At some point I decided to change grits...which most experts say is a no-no, probably correct, but moss was starting to grow on my head with impatience. I relaxed the screw, cleaned the brass, re-assembled & just out of curiosity measured the barrel diameter on ends vs. now relaxed/contracted middle bulge area. Sorry don't have numbers in front of me right now, but lets just say 'a lot' relative to thousanths of bore diameter. The laps job is to hold grit, but some barrel consumption seems inevitable. I could see a greasy yellow tinge in the slurry.
Personally I've concluded the bore has to be as close to bang on within a couple thou of target diameter prior to lapping & of course as straight as possible to begin with. Or, you make up for it in lapping time & related consumables. But I'm also no expert, just an opinion thus far.
What the very first couple lapping passes showed me as the surface started to matt up was, despite my best efforts on the prior boring side, spring passes, locked carriage, changing travers & rpm speeds etc. there is a bit of technique to getting the bore geometry right beforehand. Lapping really hilites that. What could be called bell-mouthing might be an artifact of boring. I'm not saying this is the case in Brian's liner because he looks to be at matt finish stage.
I also did a test of the auto-parts 3-stone brake (deglazing?) hones. It didn't take me long to throw in the towel there. I had a very consistent straight bore to begin with & it turned bell-mouthed in no time. There's probably a technique to that too that I could improve on, but it wasn't for me.
