- Jun 24, 2010
- 2,445
- 968
The gear idler shaft is made from 5mm O1 tool steel. The end has a M2.5 threaded hole for flathead screw that retains a brass end washer in position. Including some pictures of one of my (many) lapping trials. My experience with drill rod is that is always within the stated tolerance, but is often eccentric in cross section. So, the purpose of lapping here is to bring it to size with appropriate finish, but also make it circular section. Here I have a steel clamp with a thumb screw tightening nut. It holds a sacrificial aluminum lap, slit through & also some internal relief slots made with a jeweler blade in scroll saw. I have a selection of inexpensive (AliExpress/Ebay) diamond lapping compound of graduated grits. The method worked reasonably well. But I have subsequently come up with an easier, less messy tool which is now my go-to method. I’ll show that tool a bit later.
After lapping & parting off, I torch heated & oil quenched. Then into the toaster oven to tan brown. I discovered it is sufficiently hard because I discovered the countersink was a teeny bit shallow & had to grind it bit to deepen, because my HSS tool just rubbed it. All good, everything seems to run smooth.
