Thank you Michael.
Helical gears installed.
I turned the cam shaft supports over 180 degrees and drilled and taped for new holes. The driven gear is slightly larger than the original so I had to space the supports out about 0.125. The cam shaft was also replaced with a longer one.
I was able to move the flywheel in to where it should be since the drive gear is centered over the driven gear and not off to the side it gave me more room.
The clapper bar was moved down about an inch and the turn buckle was lengthen to fit.
Comparison video
And now the final video.
I want to thank everyone who left comments and likes along the way as it is appreciated.
Thanks for looking
Ray
Comparison video
Thanks for looking
Ray
