- Jun 24, 2010
- 2,455
- 974
Before leaving the crankcase for now, I wanted to elaborate on the oil bath lubrication details. I mentioned the O5 design calls for the nose housing to be partially filled with oil. The cam plates, planetary gears & bearings spin inside this housing so bath makes great sense from that perspective.
This view shows the approximate oil level based on recommended fill up volume. Notice how the bottom set of tappets (cam followers) would always be submerged in oil. I envision even medium viscosity oil working its way out through the annulus gap between the cylindrical tappet & the bronze bushing ID hole. The tappets are sliding fit & perpetually moving up & down. So possibly even some light pumping action. Maybe any bypass oil volume is minimal & just migrates down the pushrod tube where it ends up in the lower covers. I’m not really sure. Obviously it must work because it’s common to the larger O9
