Consider that the action of the beam reverses what the cam does so what may have been closed for 250deg of rotation on the popping will now be open
Hi K2, The engine is blowing back all the time as it has no exhaust valve, basically the flame size and it's position has to be adjusted so the blow back doesn't blow the flame out.Hi Mike 1: Nice engine! - Curious, from what I can see, it sometimes blows-back a bit (yellow flashes past the burner head) and sometimes it doesn't? - Is that correct? - Does this vary with flame size?
Thanks Jason the engine really tried my patience trying to get it to run.What is showing on the video is probably when the frame timing matches the engine at a specific part of the cycle giving the impression that at some times there is more blow back than others.
Nice engine Mike and not one you see many of.
Methylated spirits 'denatures' ethyl alcohol by adding 10% methyl hydrate/methanol to it. Methanol/methyl hydrate, available at most Canadian hardware stores, is ASTM purity grades A and AA, both are 99.85% methyl hydrate.Methylated spirits is the same as denatured alcohol.
Andrew in Melbourne
I still wonder about the mass of the flywheel. These things do not have much power. I wonder what would happen if you removed one of the flywheels so that it did not require as much power..Today was a day of rest. No machining, no thinking about machining.--It was great!! This afternoon, I brought my old Poppin engine down to my office to see if it still ran, and where the flame valve was in relationship to the piston position. After bit of confusion (I couldn't remember which way it was supposed to rotate), away it went, running like a trooper. Now I will try and sort out the timing on my new cross beam engine and see if I can get it to run as well as the Poppin.
