I've been reading my posts from when I built the Poppin engine a few years ago, sorting out the timing of the slide valve that opens and closes the cylinder port. Thankfully, I give a good written description of the timing sequence during that build. The Poppin engine had no exhaust valve on it, as due to the design if any positive pressure built up in the cylinder, it just blew off pressure by lifting the very thin gauge valve plate off it's seat. I may have to add an exhaust valve to my engine to make it run properly, but I will first try to run it with no exhaust valve. Fortunately, the exhaust valve is not difficult to build.
