my first I.C.: a V10
Hi,
next few parts of the carburetor prototype:
image.php
image.php
image.php
Greets Frank
Hi,
some news on my last challenge :p
i made yesterday and today the timing wheels and taperlock-bushes:
the wheel after milling the teeth:
image.php
in foreground 3 wheels in 3 different stage of manufacturing:
left like abvove
right turned a recess for the disk beside the wheel
middle: contour for press-form the disks
(please - if you can name me the right words on it i'll edit it - but:
i don't like to google quad of a hour for every special word ...
i think you understand :) )
image.php
pressed disks in detail:
image.php
2 wheels after turning the surface - one in pressed stadium
image.php
result: necessary wheels for my engine :)
image.php
one wheel i made to test some things like "how stable is the pressed/transformed disk ...
and on this wheel i tested how it would look when finished
image.php
that wheel fitted on my engine
looks like "made for it" i think .-)
image.php
the taperlock-bushes in very miniature .-)
the 2 screws are M3 x 4
Outer diameter of the bush iss 15mm, bore 4mm
image.php
the selfmade tool:
image.php
Frank
Frank.
Only have to say, great work. th_wav woohoo1
One question: You are going to split the tapered boss, eh?
Best.
CS
Hi Frank,
Absolutly fantastic !!!
Alexandre
Hi Alexandre,
thanks for the praise :)
today i finished the timing wheels:
turned the profile inside
mill the webs
glue & slotted the bushes
image.php
and it looks not bad i think - the relations to the engine
image.php
Frank
Frank,
Please, some doubts:
- What is the angle for a V10 engine ? In the V12 can be 60 degrees or 90 degrees in the V8, right?
- What is the positions of the connecting rods bearings in the crankshaft ?
V12:
O
X
O O
V8:
O
O X O
O
Do you understand me ?
Thanks,
Alexandre
Hi Alex,
the crankshaft has an angle of 72° also the angle between the cylinders
1
4 5
O
3 2
here you see the firing order also
the engine is left rotating,
Cylinders 1 & 6 on the same crankpin, 2&7, 3&8, ...
firing order: 1 - 6 - 5 - 10 - 2 - 7 - 3 - 8 - 4 - 9
Frank
Yes !!! I understand.
Very thank you Frank.
Alexandre
Hi,
last days i made some small things and opticals:
mill some roundings
turn the 20 tappets (the patrts between cam and valve)
a lot of work because every part individual made to adjust the clearance for the valve
image.php
luck to have a friend who lend me a 1/4-32 tap to made the
spark plug threads - a look from inside:
image.php
(valve dia 11mm)
after finish of this terrible job a probe fit of the heads:
image.php
an idea for the carbs:
image.php
everything not very difficult but the needles ...
i'll see what i do ...
10 carbs will be a very imposant view and maybe a unforgettable sound when trottle ... :)
Frank
ahh
i have forgotten s'thing:
what do you think:
is it sufficient to use carbs with a inner diameter of 4.2mm ?
(in the case i use 10 carbs)
i can get 10 carbs with 4.2mm on very low price.
disadvantages:
- not D.I.Y. :-( :)
- very small on 10ccm (.65) on every cylinder ...
- not always metal
Frank
I have read that a single carb can handle up to 4 cylinders. This is because they draw at practically nonoverlapping times of the cycle.
If this is correct, 5 rather than 10 would be more than sufficient.
any thoughts welcome,
tom in MA
4.2mm is more than large enough for a .65 bore. I would only suggest that trying to balance 10 of them would be a nightmare. As far a the material, what does it matter? Most engines today have some kind of plastic on them so we can do the same thing.
gbritnell
5 scale twin-choke Weber style carbs would look great on that engine, and only 5 to balance ...
Hi,
the timing belts arrived today :)
first made 3 very small pulleys ...
attachment.php
Frank
This one has the look of a Schillings design...wahr oder nicht? Alles ist sehr schoen!!
James
Hi,
last few days not done a lot
But the small things will take most time :-(
image.php
image.php
Frank
Yes... Frank !!!
Good news !!! th_wav woohoo1
Take care,
Alexandre
