How to machine these tiny parts, especially the cross-hole?
Here's one way not to do it. I drilled holes in a plate the thickness of the length of the pins and put over-length ones in:
The idea was to mill them off to the correct length. But I made the fit of the pins too loose and they spun when the end mill hit them. Also chipped the teeth on the carbide end mill....another one bites the dust!
So I drilled new holes in the plate so the pins were a fairly tight press fit into the holes and that worked well to machine them off to the correct length:
The longer one is my indexing pin, for the next step. I had the spacing exactly .2" on centre for the pins, as well as the index pin. So with that known, I flipped it up on end, indexed off the longer pin, and accurately drilled the cross holes:
Then I just tapped the pins out with a pin-punch and job done!
Rick
Rick
