- Sep 5, 2008
- 46
- 13
Nice work, Ray. I really like the way this is going!
Thank you for the kind wordsAlways a great pleasure to see a well thought-out personal design taking shape, thanks to share the build !
Thank you Sir much appreciatedNice engine.![]()
I made and polished the flywheel taper locks and mounted the flywheels on the engine. Everything fit and lined up correctly.
It was time to make a wood base for the engine and I had a piece of poplar that would work fine. Before applying the finish to the box I drilled holes for the wiring and made a cutout for the switch.
This is what it looks like with a spray finish and the motor mounted.
I polished up the cylinder head and drilled and taped for the spark plug.
A view from underside showing the electrical components and the rubber feet.
Thanks for looking
Ray
