Cylinder liners done. I started making them as I described, cutting the material to length to get 2 liners. Drilled them with a 14.5mm bit (.571"). I wanted to get close to the finished diameter to not leave too much to bore out, but not go over with any drill wandering. That size worked out well.
Machined the first few on the CNC lathe. Did one end, flipped it around and did the other end. Only issue was once machined the one end was not a good size for any collet I had, so I made an adapter to hold the machined end while the "new" end was being machined. Worked out OK but I wasn't thrilled with it. Material blank (5/8" diameter 12L14), adapter piece to fit in a 1" collet and hold the machined cylinder, double piece finish machined, after being cut.
I had left enough material to cut the double length piece apart, but after machining I realized that I cut it very close and there wasn't enough length on the large diameter in the middle for a band saw blade thickness, or even a normal cut-off tool. So I used the thin cut-off tool I made for grooving the valves and it worked perfectly to separate the 2 with only a .020" kerf. Then cleaned up the cut end of each on the lathe.
After the first few I realized that the bore in the lathe head is larger than 5/8" and I could drill about 1 1/2" deep on one end of the full length bar on the larger manual lathe, machine a cylinder on the CNC, then cut it off, drill the hole deeper in the bar, and proceed with another cylinder. So basically worked with the full bar without needing to cut off a length until a cylinder was machined.
The set of 8 done:
Installed with red loctite:
Some of them were a touch tight and some were a touch loose, but the loctite should retain and seal them. Even a tight fit needs something to seal liquid-tight.
Next, the pistons.
Rick
The set of 8 done:
Next, the pistons.
Rick
