Yes, I cut 2 cam lobes a bit too thin on my first one. I think a key point here is to blue and mark all the cuts first, so you can see that they all look correct before cutting.
One or two things to check for with lathe CNC: 1) make sure that both you and your software(s) are using the same definition for depth-of-cut, i.e. radius or diameter, and 2) make sure that both you (during zeroing) and your software(s) are using the same definition for tip of tool.Yes, that is how I'm doing it. I turn it down to .098" dia for a short length, cut the groove, then come back and turn it to .094" dia up to the point in the stem where the diameter changes. So it isn't a deflection issue with the groove. It must be something wrong I'm doing. I did get the groove close to the correct depth a couple times, but then tweaked things a bit to get it correct and sometimes it works and sometimes works the opposite.
I'm using EziLathe to generate the code, which is a pretty cool program. When I run the code in that simulator the groove almost cuts the part in half. In reality it doesn't cut deep enough. So that is the strange part. The tool setup is correct on the machine. Something strange I'm finding is that if I stop the machining before it is complete (like if I see that something is not right and don't want to complete the test part) and return tool #1 to 0,0 it isn't the 0,0 that it started out at. So something is changing the 0,0 point and that is throwing things off. But not if the machining completes. A setting in mach3 that is wrong? I should probably ask on the mach support forum and post my code.
I don't have issues with mach3 on my CNC mill or router. If something is not machining correctly I can usually find what I did wrong. But the mach3 turn seems to be a whole different story. After doing some searching around on the net it does seem like most people agree with this. I'm always up for learning new things so thought it might be interesting to dump mach3 on the lathe and get something else. Why not start a whole new system with its frustrations?
Rick
Nice work, well done.Now that the wordy introduction is done, on to the crankshaft.
I’ve never made a crankshaft like this before and from everything I’ve read, it was going to be a challenge. The issue, as far as I could see, was that the drag of a lathe tool against a fairly flimsy crank can easily lead to it bending, jamming, and being ruined. So how to minimise this?
Here is how I did it. I do have a rotary table for my CNC mill; the 4th axis. But the mill is not huge and there is not room for the 4th axis and a 6” length of material sticking out of it. Here is where things get weird.
My new mill, the PM728 is beside the CNC mill. So I bolted the 4th axis onto the table of the PM mill, but left it plugged into the CNC mill. So I wasn’t using the 4th axis under CNC control, but just using the software to rotate it as needed manually. Here is the setup:
The idea was that I could use the mill to machine away most of the material. I figured a rotating cutter would put a lot less stress on the part compared with cutting it in the lathe. I roughed out the main journals first, as those didn’t require any offset of the crank. So far, so good.
A test cut at the right and then on to the main journals.
I’ve bought a number of kits from Hemingway Kits over the years and highly recommend them. Oh, if you do any threading on the lathe, their retracting tool holder is fantastic! But I digress. I had their Keats Angle Plate kit for a while but never got around to making it. So a time out while I made it. OK, now I’m back. This holder allows for a fairly easy setup for offset turning.
So what I did was to slowly lower the cutter in the mill spindle, while using the 4th axis control to very slowly rotate the crankshaft. I would allow it one complete rotation and then lower it another .010 or so. Of course the surface finish was not good enough for a finished journal, so I left them all oversize to finish on the lathe. This way I only had a few thou to clean up and with slow and careful work didn’t bother with putting any filler pieces between the journals to stiffen it up.
Did it come out perfect? No, but hopefully close enough. Once back on the lathe I cleaned up the main journals to get the runout near zero. I was a bit surprized how flexible it is.
I decided not to push my luck and machine the crank offsets to look more like a real crankshaft. I considered myself a bit lucky to get this far with my first crankshaft.
So that is my multiple mill, semi CNC, rotary table, crankshaft production. Of course a normal rotary table would allow you to do the same thing, just with a lot of cranking. But if machining the crankshaft right from the start on the lathe frightens you, maybe consider this method.
Rick
