- Aug 18, 2008
- 343
- 135
Many years ago there was a group of model builders that built a dozen or so Briggs and Stratton model FH engines in half scale from patterns made by Norm Brockelsby. I have only seen one of these engines, but I remember that the air shroud on the model FH was made of cast brass. It was a very true likeness of the original shroud, but obviously was made thicker due to the casting process. Unless you looked closely, or tapped on the shroud it was hard to tell it was cast. The external finish was polished smooth. Your mockup shroud method could be revised to make a good lost wax type casting pattern. Brass foundries are not usually hard to find. Good ones are a bit harder to find.
Jeff
Jeff
