I have been developing the capability to cut the gears for the Wallaby. I will be using the tools and techniques I picked up from Chris over at ClickSpring. If you are not familiar with his work, look him up on YouTube, he is very talented and makes beautiful videos. I will not repeat his instructions here as I could not do them justice. To make a gear you need to be able to cut the spaces between the teeth with a properly shaped cutter, and to make the cutter you need special lathe cutters, mandrels, cutter blanks, and sharpening tools. This is where I started. Below is a picture of the print for one of the spur gears and an aluminum test gear, the final spur gears will be made of brass and the pinions of steel.
This is the print for one of the two pinions
Sheet two has the information necessary to create the cutter to cut the space between the gear teeth.
Below I am practicing making gear tooth cutter blanks from 01 tool steel.
Below is the beginnings of one of the button cutters that will cut the profile into the gear tooth cutter. these are precision diameter made from 01 tool steel and hardened. In the back ground is a tool that allows the proper relief angle to be cut into the button cutters and is also used to precicley sharpen them.
As seen below two of these button cutters are mounted in a holder and cut the proper profile into the cutter on the lathe.
Then the mill is used to create the face of the cutter.
Below is the gear tooth cutter ready for heat treatment.
This is a rotary table that I picked up from Amazon and uses the same chucks as my lathe. I use some Arduino code and a PC to advance the gear blank the correct amount so the mill can cut each tooth space.
I cut the gear blank to diameter on the lathe, then move the entire chuck and work piece to the rotary table on the mill. then I cut each leaf (the space between the gear teeth).
Finally I move the chuck back to the lathe and perform the other operations to finish off the gear.
