"Topsy" 0.375c.c. compression ignition engine
RR17,
The Topsy has such a long front bearing that there should be no need to lap them, but because it is a front rotary valve a good fit will be necessary. On my small engines, I turn the crankshaft a few "tenths" oversize and then polish to size with 600,800,1000,1200 abrasive paper in order with a drop of oil. I back the paper with a piece of ground steel like a parallel. This will not take out all the machining valleys, but will smooth out the hills to give more of a bearing surface.
Nice work on the Topsy. The way you are going it will be a fine engine.
Gail in NM,USA
Thanks For the reply GailInNM very useful and i will put it to use in this project of mine :)
Best regards
RR17
more progress :) . Bored out and screw cut for the fuel tank to screw in . and also pressed the main bearing in .
Best regards RR17
There are some problems im having though because of the size of the engine i cant use a boaring bar, i tried to grind one up but it just chattered to much. For example to do the main bearing i would of idealy boared it near size then ream it out. instead im having to use a drill then ream it, But the drills are wondering! So im doing the best i can. Next Engine BIGGER lol. Like the one your doing sean.
Best regards RR17
RR17,
As long as you use aluminum you will be fine. Ti is for the birds! :eek:
Sean
heey guys quick update ive looked more closely over the drawings and ive found out im missing quite a few dimensions on the cylinder, and few other things. So for now the project on hold till i get some more.
However on a brighter note ive got some drawings from hom shop machinist i think it is, and the engine called "Alpha". Ill get some pics up have started the crankcase so far.
Best regards RR17
RR17,
Sorry to hear about the Topsy, I was looking forward to it. Can't wait to see the new "Alpha" project!
Looking forward to it,
Sean
