For those of you who thought I could change the pivot points or remove material from the top of the governor weights----there simply is no room to do this. The top side of the governor weights where the pivot pin goes thru is simply a narrow band of material which can not be made any smaller. There is nowhere to move the pivots to. The space for this governor is very restricted. This is the kind of thing that either works the way I have it, or doesn't work at all. It does work, but only at higher rpm than the cam shaft never reaches. That is why I'm changing my design to the crankshaft which spins twice as fast as the camshaft, and has more available room.---Brian
