Well, all good things must come to an end. I'm happy with this engine. It hits, it misses, and it keeps running. If you don't know---there are a myriad of things to "tweak" on these engines to make them hit more often---miss more often---switch from hitting and missing to hitting every other stroke while running under load. Counterweight size can be changed. Counterweight spring can be changed. Spark timing can be tweaked. Valve timing may be tweaked. Diameter and weight of flywheels can be tweaked. Carb needle setting can be tweaked. All of these things can be infinitely be tweaked until you get the results you wanted. This engine is finished and it's time to put it up on a shelf with my other fourty engines. Hope you all enjoyed it, it's been fun from my end.----Brian
