Hi guys thanks for responding.
Firstly I appreciate your coments but hasten to say I hope mine won't be construed as some kind of rant or whinge based on some kind of expectation :-[. That was most definitely not my intention - it's just I get a bit worried :
I have indeed noticed the number of visits Don and that is where I find the paradox :-\ If no one says anything I begin to get uneasy that I'm forcing something on people that isn't what is wanted. Truly, I don't wish to be considered in that way however, I do appreciate what you are saying and will keep your thoughts firmly in mind from here on.
Ian, it's good to hear from someone with a similar interest. If I can help in any way just ask. Though I have operated them for many years I don't have a vast knowledge on engines - you T/R boys are the ones for that
but if I can I will. My only involvement with T/R was through the very low key 'Mini Goodyear' event (my wife Sue was the pilot) for a few years and a very short foray at that time into vintage. I can't help with the Super Tigre but I do have a set of CAD drawings (currently being updated) for the ETA Mk1 and 2 should you be interested
Not much to report today but to keep 'Steamer' Dave happy here's another one of those simple but extremely useful types of fixture that will no doubt be recycled for something similar in the future......Made from a piece of scrap ally plate (hence the milling cuts) this was bored on the faceplate to hold the front housings for milling the webs. When it was split it closed very slightly - enough to tighten onto the housings - by passing the clamp bolt through a nut in the gap it was very easy to slacken the bolt and use the nut to prise it apart slightly to allow for easy movement
The sides of the webs were defined first by a series of plunge milling cuts (about .5mm at a time) At this stage the rotary table was locked and not used for indexing the part. Indexing was done by slackening the fixture and rotating the part to the next side, squaring it off the back column. By having the table stops set all movements were evenly spaced about the centre.
Once all four webs were defined the the remainder was removed by rotary milling - again indexing the part rather than the table. These milling ops were the 'roughing' using a 3/16 cutter - tomorrow it will all get repeated with a 4mm for finishing
And so far tonight they look like this....
Dave - I know what you mean re making fixtures. I really have to force myself if something like the angled block for the cases needs making - always looking for the easy way around it but sometimes you just have to bite the bullet and get it done. The bummer is, on something like that block, is that it's very unlikely to be used for something else :
Regards for now - Ramon
