MuellerNick
- Oct 5, 2012
- 398
- 191
Clamping those patterns:
You might ask yourself how I do clamp all those patterns, no matter how small or big.
Easy for core boxes, they can be clamped in a vise.
Well, I asked that when I started milling them. The most obvious option is using a vacuum chuck. I didn't like that for two reasons:
I don't have one (might cast one next year).
I don't like the idea of having a pump running for hours. Making noise, costing money, and what happens if you have to pause a job?
So I thought about a way to clamp that block material in a way that is solvent based. Well, I had no good idea exactly like that, but something along the line:
I use cut-offs of the block material, mill ribs and glue the stock onto the ribs with CA glue.
Why ribs and block material?
This has four advantages:
I can easily saw off the work with a saw blade (hack saw),
The CA is harder than the block material, so it works like a shield that prevents cutting into the work. Going too much down, you cut the solid material -> blade goes up. Cutting too high -> cut into the hard CA -> blade goes down.
Furthermore, the ribs do give room for the clue the be squeezed to the side, thus making a very small layer of glue (precise reference).
Also, I do have a precise reference for Z = 0, as I mill the surface with that milling bit.
And last but not least, you can mill into the chuck. That's a requirement if you use ball nose/bull nose mills.
After cutting off the work from the "chuck", I file off the remains of the ribs and dissolve the CA with acetone.
Medium viscosity CA works best.
While milling those tiny parts today, I thought I make some pictures.
This is the smallest part I milled for the patterns. Its footprint is 5.5 * 8 mm, 4.5 mm high. Mill is 1.5 diameter, and the cigarette lighter is scale 1:1.
Different view of that part. You can see the thin skin that remained from roughing and the fact that I cut into the ribs while finishing.
Usually, I make those ribs 1 mm wide. Width of the groove depends on the mill's size. Here it was 1.5 mm. Usually, it is 4 or 6 mm wide.
Nick
Nick
