Casting #33. Long version of fence post.
This was the trickiest casting until now. I thought it will be a piece of cake …
I had to tweak parameters more than I would like to know. Just one notch up or down with the vacuum, and it fails. Just 10 °C off with the temperature, and it fails. I also had to go up to 750 °C, I normally cast the vacuum assisted parts with 680 °C.
As cast. No, that would not work as a lathe part.
Different stages of failure. I do have more of them!
The core box. No pictures of the mould, I used up all of them.
Casting #34. Step of the platform's ladder.
This one also drove me nuts. But it wasn't as hard to crack than the fence post.
I also do have to cast that one very hot.
From the top. Ingate still in place. There will be a bore instead of it.
From the bottom.
With the gate and runner system in casting position.
Different failures. Here too, I do have more than I dare to know.
Core box for the lower layer, will be flipped over.
Core box of the middle layer, with the gates (bores going through).
And core box for the runner system (top layer). All three layers will be stacked and glued together.
Yes, initially I wanted to cast four in a go. But that didn't work that well. So I changed the runner's core box to feed just two cavities.
With the previous two castings, the model gets some visual scale reference.
Next, I'll mill the core box for the short version of the fence post. I think I learned a bit to make that one better. And I think I have found a way to cast the double walled exhaust tube…
Nick
