Managed to get a bt of shop time in yesterday and today and have the two cases virtualy finished and finally begun work on those front housings.
I guess you must be getting fed up with all these case pics - it's gone very quiet out there - but here's the last few for those who may be still be hangin on in there .....
Set that spigot onto a block as a temporary fixture for finally cutting the rear web
Also used for trimming the lugs to profile
The rear sleeves were drilled bored and reamed then set on an expanding mandrel for taking the OD's down (.5mmwall thickness). The pic makes it look like brass but it is in fact drawn Phos Bronze. It proved a real pig to drill despite freshly sharpend drills and got extremely hot but bored and reamed the last .2mm without a hitch
Back on the angle fixture the 4mm hole previously drilled was indicated then the intake drilled through..
.. the venturi taper turned....
...then transfered to the mill for the last but one op drilling and spotfacing for the spray bar
With another couple of hours spent with an assortment of needle files and rifflers, various grades of wet and dry paper stuck to differing shaped hard wood sticks, Garryflex blocks and 000 wire wool they are ready at last for bead blasting. The last op, to put the groove in on the end of the valve housing will get done after blasting.
Well I guess a big sigh of relief is called for as it's all been a bit long winded but seeing them there on the bench makes it worth it. I hope however I haven't stretched your attention span too much, my apologies if so :-[
At last however the next part (the front housing) can be tackled and one which should be much quicker though still requiring some fixture work.
These few pics are of the ops carried out today...
Began by setting up the same as the case and drilling, boring and reaming for the front sleeve as well as boring the ballrace housing and front register
After the turning the holes were drilled on the mill using coordinates .
Held on another expanding mandrel the front portion could be tackled....
Now theres a fair session on the rotary table ahead but I couldn't resist this early look
That's a lot of pic's - hope that's not 'overload' :
Regards - Ramon
