1/5 Chenery Gnome Rotary: Piston fit with cylinder
Almost have one aluminum piston so far: everything is just about perfect except the wall got very thin at the large opening at the bottom of the skirt. The wall here is probably about half as thick as it should be as per the drawings. Not sure if it’s usable or not, there are a lot of steps to machining just one piston. This is my third one too. I made a couple of dumb mistakes on the others. I found that the 0.625 root diameter on the crown of the piston is a critical measurement. Otherwise it doesn’t fit right into the slave fixture and the gungean hole will be off… Also, again, I’m having trouble with the thin wall at the opening of the piston. My first one was perfect, but I screwed something else up, I’m using a 11/16” End Mill four flute cutter here rather than a boring tool…
    1.4 MB
    1.5 MB
    1.4 MB
    1.6 MB
    1.9 MB
    1.7 MB
    1.4 MB
It's a job for a small boring bar, you are probably getting chatter on the large 11/16 cutter which is causing it to cut oversize and it may well also be bulging the skirt making the piston OD larger.
EXACTLY, chatter mainly with the lathe and wobbled eccentrically . First attempt with large 11/16 End mill on milling machines went well - amazed me; cut like butter, minimal chatter. But since then, having trouble getting concentricity with milling machine…. You’re right, boring bar would be safest and best precision. Thanks.
Finally got a good one; not perfect, but good. I don’t have DRO, but I can see now how useful that would be.
    1.5 MB
    1.9 MB
    2.2 MB
    1.9 MB
    1.9 MB
    1.9 MB
    1.9 MB
    2.4 MB
    1.9 MB
It would be easier and quicker to put the flat bottomed hole in and bore the skirt on the lathe then just use the mill for the slots
    949.3 KB
    498.7 KB
Nice, helpful photos. I would need to drill quite a sizable hole in order to use the boring bar. I was kind of plunge cutting with my end mill cutter in my mill. I would get perfect concentrity using the Lathe - boring bar. You didn’t plunge cut this skirt bottom hole, did you? Also, what is that ‘fixture’ that you show on your slot cutting photo? I would like to get one.
fixture ER32 Collet blocks www.amazon.com/Xetilmo-ER25-Collet-Chucks-Block/dp/B0CYFLS1K8
collets are typically sold in sets or separately. ER32 collets have more "range" than a 5C collet. for example 1/2" ER collet will clamp from ~0.460 to 0.500 (usually will grip up to 1mm undersize - but never grip bigger than the stated collet size). If you acquire a set, read this link to learn how to properly fit the collet in the collet nut.
https://tormach.com/articles/er-col...cpKopoq3r7n3YHvDfTBn8RqEfWNfY_gNve45us9WSBSly
Yes it's an ER 32 collet block ( square one) the advantage is that you can hold the work vertically to mill the slot then move the block so it is horizontal and then then drill the wrist pin hole and as you are referencing the square face of the block the hole will be an exact 90deg to the slot ( don't remove piston between the two operations. I also have them in ER25 and 5C
That particular piston the slot goes all the way down so I just drilled a hole to depth to make putting on a cut for the slot easier as well as making room for the boring bar. That piston is 20mm dia so about the same as yours. If it were your piston I would do that hole on the lathe, drill just undersize and then finish with a flat bottomed cutter, then do the skirt with the boring bar so keeping it all concentric.
Piston ring ‘Gap’ question: i’ve made half of my piston rings so far. Used cast iron and came out very precise. However, mine are about 2000 thinner due to my slightly thinner piston ring grooves. But all is neat, clean and precise. Here is my question, the gap that’s shown namely 0.015 inches should that be the gap when measured at the time of placement of the ring within the cylinder? Will the heat create this gap ( using a metal ‘gag’), or do I cut this gap and then Anneal the metal ring?
I break the ring, spread it and heat treat and then put it squarely in the cylinder and set the gap.
15thou sound sounds a lot on a 3/4" bore. I would be looking at more like 3 thou
Jasonb, I appreciate your speedy reply. I am in my workshop now about to continue with this compression ring fabrication. Maybe he has 15 thou due to expansion of the cast iron during the heat treatment, annealing process…? I like your explanation of how you would do it, I only have two steel cylinder liners made so far; yes, I am jumping around ahead of myself from time to time, but I’m glad I am doing it that way in case something doesn’t fit. I don’t want to have nine mistakes I would rather have only one or two if that makes any sense .
Jasonb, after breaking the ring between thumbnails and spreading it, would you keep the spread by placing a metal gag and then heating it where it would then fall off the gag due to slight expansion…?
When you heat treat, are you allowing the part to drop down into a small water bath? Or are you letting it cool slowly? Thanks.
I put something between the two broken ends to spread them to the required gap. Heat as evenly as possible otherwise you can get an egg shaped ring and then allow to slowly cool.
I break the rings with flush cutting snips on the flat surfaces - top and bottoms as seen in the photo. once they have been spread and heat treated they will hold the spread size which gives them the spring when you compress the to fit into the cylinder
    343.7 KB
    271.7 KB
    906.4 KB
    937.7 KB
How soon can I keep the piston / rings inside of the steel cylinder sleeves after fitting them? Is there an order of assembly that you could suggest?
I would not fit them to the pistons until all the parts have been machined and assembled. Far easier to feel if there are any tight spots when there is no friction from the rings. They are something you usually fit at final assembly.
Think I have it figured out but need to be sure: there should be no ledge or shoulder extending beyond or proud of the steel liner thickness where the steel cylinder liner ends and the aluminum cylinder head bevel (20 degree) begins. There is only a small should to accommodate the steel liner thickness here so that the transition going up is smooth.
I believe one photo shows the ledge as extended, and the other shows the ledge being taken down in order to create a smooth transition. Where the bevel in the aluminum begins. Would it be true that the extent of the past piston will only go as far as the, connecting rod allows it. The head of the piston should not bottom them out at any type of ledge?
    1.9 MB
    1.1 MB
    4.3 MB
