Lakc
That spur gear stock sure comes in handy, looks great.
jpeter said:Sure looks good. That'd be a good way for making an oil pump for putting in the crankcase.
I thought though water pumps were impeller types for the volume?
jpeter said:Does the fit have to be pretty good?
petertha said:- is the wristpin end also bushed like the bottom end, or plain?
- what type of bearing material did you use?
- on assembly, would you locktite the bottom end bolts, or normal torque is ok?
- material = dill rod? hardened?
- what keeps them retained in the piston
