My one boss/foreman was a diesel tractor puller and was telling me that he was @100 psi boost on his tractor and some guys were over 100 psi, wow! He also really hated the turbine guys.
Ray
Ray
I forgot. That’s amazing that those big electrics are sheet metal construction using the term lightly haven’t seen a sheet metal motor since my HS friend had a CRosley. I wonder if the tech could be applied to models. Might make cylinder blocks of v 8 more practical. Bolted and pinned. Oh my gosh time for refill of coffee. LOL. Can’t wait for design thoughts along this line . You will be the starting consultant! I just bough som aluminum bar stock close to $200 worth that I probably can hold in one hand. You won’t believe the price of copper my son is having trouble getting 4130 tubing for the race cars he is building. Suppliers only sell 4’ lengths. 8’ doesn’t exist any more except for one or two suppliers. The shippers don’t want to ship long lengths either.It’s like going back to school I learned something today.LOL I friend and neighbor at the marina had a very big yacht it had Detroit diesel with 8-71 roots blowers fed by turbo chargers it must have been a pretty old boat but well preserved . I forgot to ask about boost on those big engines. We had race versions of 8-71 blower or supercharger. 25 psi boost was not unusual on the alcohol motors actually very reliable if you took care of them we ran a lot of over drive on the blower knowing that 8000 blower rpm was the end of efficiency. We traded that for the instant huge boost right off the line. I did work as we had some pretty good success on the 1/8 mile races. Now they get into the 65 psi+ but it’s hard on parts. I just got my castor oil a few minutes ago . I’ll be able to test it side by side with canola oil. Once I get these test done I’ll post them . Also got the digital tachometer just like the farm guy used in his testing . I’m going to order an ultra quiet air compressor shortly as soon as I find the quick disconnects I want . Standard shop ones are just too big and clunky for model use. Also hot the air line lubrivator and moisture trap. My coffee pot is on the way out so I’m thinking I could make a coil of 1/4” copper tubing an submerge it in the pot then run the compressor air to it thus having preheated air for the mini shop . Compressed air makes air tools run icy cold in the winter so this is just creature comfort. At this time I have a kitchen cutting board of hope coming that I’ll clamp to my work table then I can add my lighted magnifying glass so I can see better . It’s a lot of Mickey Mouse stuff when you are starting from scratch . It’s a nice sunny day in the 40’s today a little breezy but not bad for dec in Minnesota. It ain’t global warming so I’m staying out of politics here best I can .LOL
Byron
You guys have made some cool dynos! So far, I've found the easiest way to make a dyno is to use an AC induction motor as an eddy current brake. It is literally already made for you, and any AC induction motor will work. You simply feed DC to the windings to increase the braking effect. Here is one I made for testing my automotive air conditioning compressor steam engine. In this vid I'm using it to test another electric motor. I just thought I would share. Cheers all. .
I've been thinking of the same thing. Another project to add to the list! Any plans available or is it something needing some CAD?So it's rated at 3,000 Hp at 918 RPM....
....Sometime in the future I would like to make a scale locomotive of a SD40-2 using a scale 645E 16 cylinder engine using glow ignition. As for excitation there are a lot of ways to do that, that is not complicated.
Ray
Thanks, I'm glad you liked it. I will be adding better instrumentation in the future so I can feed the data into a laptop, but right now I've got a big list of other things to do first. I would be happy to help whenever you're ready to build your own. Cheers!That is really cool. When I’m ready for this I’d like to contact you for some help. My system will be slower and smaller but the same target.
Byron
Thank you I’ll make the stepper motor conversion to start with and see if the steamer can drive it . Unless I can put a lot of air in to the turbines I don’t think they will do much even coupled together. The first one I ordered is not as nice as the second but I could or another of them and have a three stage turbine even so I’d guess it could take a lot of air compared to the steamer . Mean time I’ll get the boiler done and tested. I don’t want the standard automotive gages as they just take up too much space I’ve searched for the smaller steamer gages and have found pretty much what I need. Not sure about delivery. Some come from Europe so shipping might take longer, but my son has had pretty fast service from Europe and Australia. The boiler will have 1/8” or 1/4” fittings rather than metric pipe as the engine has. I found a tap and die set for the metric pipe threads but it’s over $110 for three taps and one die. fittings one source did that these metric pipe threads can be whittworth. I haven done a whittworth since I was an apprentice. My machinery manual is out at sons shop 65 miles away I don’t get out there regularly so I’ll look them up next time I get out there I did look on the internet but I’d rather have the book right in front of me. They may even need a fiber washer under them as I don’t think they seal like npt does with just a little Teflon tape. It’s surprising how many fittings you can need the boiler is 1/4” wall aluminum tube standard 4” copper water tubing end cap cost almost as much for 1 as my entire order of aluminum I got free shipping too. I can get AN#3 fittings and use 3/16” Teflon flex brake line but it’s going out of favor and being replaced with 1/4” line so I may just go with it as it looks nice as stainless braid covered. My son has the fancy assembly tools too so a tough job will be easy for a change . Well it dinner time nice outside for winter here. 35 deg right now no snow at all.Thanks, I'm glad you liked it. I will be adding better instrumentation in the future so I can feed the data into a laptop, but right now I've got a big list of other things to do first. I would be happy to help whenever you're ready to build your own. Cheers!
It's something that would need to be drawn up on CAD. I have all the factory manuals which include all the dimensions. Each cylinder is pretty much a 9" bore x 10" stroke so I was thinking somewhere between 1/6 and 1/10 scale.I've been thinking of the same thing. Another project to add to the list! Any plans available or is it something needing some CAD?
The egg-beater I maintained ran 1800 shp @33,000 RPM.
Wow, it sounds like your to do list is as long as mine! I look forward to pictures of what you're up to. I've never tried using stepper motors for dyno brakes, it will be interesting to see how well that works. Do your turbines have proper DeLaval nozzles in them? If so, they may not use much steam/air at all, but they are inherently low torque high rpm devices. Cheers.Thank you I’ll make the stepper motor conversion to start with and see if the steamer can drive it . Unless I can put a lot of air in to the turbines I don’t think they will do much even coupled together. The first one I ordered is not as nice as the second but I could or another of them and have a three stage turbine even so I’d guess it could take a lot of air compared to the steamer . Mean time I’ll get the boiler done and tested. I don’t want the standard automotive gages as they just take up too much space I’ve searched for the smaller steamer gages and have found pretty much what I need. Not sure about delivery. Some come from Europe so shipping might take longer, but my son has had pretty fast service from Europe and Australia. The boiler will have 1/8” or 1/4” fittings rather than metric pipe as the engine has. I found a tap and die set for the metric pipe threads but it’s over $110 for three taps and one die. fittings one source did that these metric pipe threads can be whittworth. I haven done a whittworth since I was an apprentice. My machinery manual is out at sons shop 65 miles away I don’t get out there regularly so I’ll look them up next time I get out there I did look on the internet but I’d rather have the book right in front of me. They may even need a fiber washer under them as I don’t think they seal like npt does with just a little Teflon tape. It’s surprising how many fittings you can need the boiler is 1/4” wall aluminum tube standard 4” copper water tubing end cap cost almost as much for 1 as my entire order of aluminum I got free shipping too. I can get AN#3 fittings and use 3/16” Teflon flex brake line but it’s going out of favor and being replaced with 1/4” line so I may just go with it as it looks nice as stainless braid covered. My son has the fancy assembly tools too so a tough job will be easy for a change . Well it dinner time nice outside for winter here. 35 deg right now no snow at all.
byron
Hi I had a stroke of good luck to day I found immersion electric water heaters. There are a few wit 1” npt threads too these are 110 vac however you can get 220 too and higher output . One of these will just fit in the boiler I’m building so I won’t have to use the Rc hot plate except as backup I don’t have enough circuit power I don’t think to run two of these heaters and there is no 220 outlet withou some electrical mods. I really don’t want that .since my boiler is aluminum I’ll wrap it with header insulation under the outside jacket . There is a smaller one so maybe I could add a lower wattage as a booster . I’ll drill and tap the end caps for 1” npt on both ends just in case . According to the charts I found it should only take about 10 minutes to get steam up. That would be nice . These are only $30 each so I might be able to not buy the air compressor but I really could use one anyway . I haven’t received the aluminum materials I ordered yet. I have the boiler tube I may make it an inch longer just for more volume . Also found a shaft driven boiler fill water pump but they are out of stock for now I ma just make a gear pump lik an oil pump instead. I have material and gears already .It's something that would need to be drawn up on CAD. I have all the factory manuals which include all the dimensions. Each cylinder is pretty much a 9" bore x 10" stroke so I was thinking somewhere between 1/6 and 1/10 scale.
Ray
I tell you what the California ultra quiet air compressors are great harbor freight has knock offs that are just as quiet . I’ve had it with noisy compressors.I pushed our garage out 12’ at one end and built a heated shop. Unfortunately the big air compressor is in the unheated garage and won’t work well in winter. I have a small pancake compressor for air tools but it is too noisy to use for air in the shop. I would love a quiet compressor if such exists. Which one are you getting?
Well I just found out that chilertern has come out with an electric boiler. It’s cheaper than the compressor but very similar to the one I have sketched up. I’ve already got everything I need except gages so I’ll finish mine in parallel as mine is twice the size. Plus twice as thick walled I can use more pressure if needed. Basically the same design but I have a bigger heater.I tell you what the California ultra quiet air compressors are great harbor freight has knock offs that are just as quiet . I’ve had it with noisy compressors.
byron
Along the dyno line I had forgotten I used placid industries hysteresis clutches and shaft brakes. These make perfect torque measuring possible the have an arm you can rest on a fixed surface then calibrate the current, force applied and compare to a chart. Simple use standard hp calculations. Many different load catagories are available so essentially no moving parts. They aren’t the cheapest thing around I’ll call as soon as possible and get a quote.Well I just found out that chilertern has come out with an electric boiler. It’s cheaper than the compressor but very similar to the one I have sketched up. I’ve already got everything I need except gages so I’ll finish mine in parallel as mine is twice the size. Plus twice as thick walled I can use more pressure if needed. Basically the same design but I have a bigger heater.
byron
Greetings,I pushed our garage out 12’ at one end and built a heated shop. Unfortunately the big air compressor is in the unheated garage and won’t work well in winter. I have a small pancake compressor for air tools but it is too noisy to use for air in the shop. I would love a quiet compressor if such exists. Which one are you getting?
My son and grand son have an auto shop they both are snap on devotees. They have gone to all battery powered impact and drivers although they still have air tools. The 1” impact will take about anything off including any part of the operator in the way . They both have so many tools it’s just crazy but newer cars take special tools for almost everything. I’m limited being at home to about the minimum power tools I inherit some of their stuff occasionally. I barely have a small socket set and hand tools usually if I don’t have exactly what I need I just walk up to orients about 3 blocks away. Tech stuff I have them come and get me then I spend the day at the shop. I plan carefully so I get done what I need in one day. This little boiler will probably take a couple days unless I can get them to help out. There is a surprising amount of detail stuff to do. I’m doing the home work now. They just got a new porta power so I can hydraulically test this boiler I know I could blow it up but I’m just going to proof test it. They have a stock tank for tire testing so I’ll make use of that . These little engines only need about 30 psi unless you want broken parts. This one is too expensive for that. I won’t even run the turbines up very fast. I can get ceramic bearings if I need but I’ll see how the stock ones do first. The big issue is they have such small shaft that just find in ding a coupler is hard. I may have to consider installing larger shafts . Model boar couplers aren’t going to last long that’s for sure.Greetings,
The low noise air compressors are great for noise, but deliver around 1/2 the CFM of a similarly sized noisy airless. I have a small Rigid that was on sale at Lowes, and it's lovely to not even notice it's cycling if the stereo is on. Beats being startled out of your skin when an airless kicks on during a moment of concentration.
With a 3/8 air hose and a 1/2 inch rapid air ring around the top of the shop (16X20) adding some capacity, my little compressor is good for one good braaap from an impact gun before having to recharge. It won't fill an auto tire from flat to full pressure without recycling several times. Don't think I'm unhappy with it though! It's great for finish nailers, staplers, air guns, and small air brush use, but if you use much air it may not work out so well for you. I'm thinking about getting a larger version of the quiet compressor for the building and putting the little quiet one under the bench where I build models and fool around with smaller stuff.
It might be cheaper for my needs to just get a decent cordless impact gun and ratchet these days, save on the space for a larger compressor AND lose the air hose dragging around behind me
Happy New Year,
Stan
Setback on new boiler. I got email from chilertern . The nice electric boiler they have won’t power the 4 cyl engine. . So I had to write that one off. Then my son called and he cut a 14” piece of 4” aluminum tube but it turns out that it’s tapered inside. I’d guess for vibration control snd it grossly out of round. One end has nearly 1/4” wall but the other is only 3/16” wall . So I’d have to make radically different end caps then because it’s tapered I’d have to make odd size tube holder for the transfer tubes. So I’ll have to order a new tube from the metal supplier. I ordered a second immersion heater in case I need more heat. I looked for a relief valve too but came up empty . I’m still looking for a metric pipe tap and die set . Unfortunately most I’ve seen are not listed correctly . They show as metric but don’t have the right ones listed in the contents . I did find more small gages then I see they aren’t very high quality . I may have to get automotive stuff .My son and grand son have an auto shop they both are snap on devotees. They have gone to all battery powered impact and drivers although they still have air tools. The 1” impact will take about anything off including any part of the operator in the way . They both have so many tools it’s just crazy but newer cars take special tools for almost everything. I’m limited being at home to about the minimum power tools I inherit some of their stuff occasionally. I barely have a small socket set and hand tools usually if I don’t have exactly what I need I just walk up to orients about 3 blocks away. Tech stuff I have them come and get me then I spend the day at the shop. I plan carefully so I get done what I need in one day. This little boiler will probably take a couple days unless I can get them to help out. There is a surprising amount of detail stuff to do. I’m doing the home work now. They just got a new porta power so I can hydraulically test this boiler I know I could blow it up but I’m just going to proof test it. They have a stock tank for tire testing so I’ll make use of that . These little engines only need about 30 psi unless you want broken parts. This one is too expensive for that. I won’t even run the turbines up very fast. I can get ceramic bearings if I need but I’ll see how the stock ones do first. The big issue is they have such small shaft that just find in ding a coupler is hard. I may have to consider installing larger shafts . Model boar couplers aren’t going to last long that’s for sure.
I absolutely hate drafting and mechanical drawing so I may see if I can get the cad program working. It’s been a while is I’ll need a little learning what I’ve forgotten . I may end up getting Fusion instead. We have been discussing a 3D printer but there are so many local places that it might just not be economically feasible
byron
