Roger B
A bit more information on hot bulb engines. The adjustable spray nozzle was fitted to the Lanz Bulldog and as rolphill says it was used to adjust the combustion conditions between light loads when a narrow spray was injected into the hot bulb and heavy loads when a wider spray was spread around the combustion chamber.
I have a couple of descriptions of the operating cycle, one from the Lanz with some useful numbers in which I have roughly translated and one from Hiscox’s book. There are PDFs of various editions of this book on the internet.
The Lanz document:
_______________________________________________________________________________________________________________________________________________________________
A complete working cycle of the Lanz Hotbulb Engine requires one revolution of the crankshaft.
First Stroke:
The piston is forwards (it is a horizontal tractor engine) and the fuel air mixture ignites. Due to the expansion of the burning gasses the piston is driven back. The exhaust ports are then uncovered followed shortly by the inlet ports. The burnt gasses pass via the exhaust ports into the exhaust pipe. Due to the backwards travel of the piston the fresh air in the crankcase is compressed into the transfer pipe and then into the combustion chamber where it drives the remaining gasses out.
Second Stroke:
The forward motion of the piston closes first the inlet ports and then the exhaust ports. At this point the fuel is injected into the hot bulb where due to the lack of air it starts to vapourise. The piston now compresses the air into the combustion chamber where the mixture is once again ignited. Due to the forwards motion of the piston fresh air is drawn into the crankcase.
The crankcase is sealed. The air can only enter via the air filter and inlet valve (reed valve). The valves stops the air being blown back out when the piston starts to return and the volume is reduced. This results in an overpressure of between 0.2 and 0.4 bar which pushes the air into the combustion chamber when the inlet ports open.
The compression ratio is between 5-1 and 6.5 -1 depending on the swept volume (I think that it means combustion chamber). The fuel injection takes place around 120° to 135° before top dead centre.
The picture in the Lanz document is a fuel preheater for highly viscous fuels like tar oils, It is attached to the water cooling system.
The Lanz document:
First Stroke:
Second Stroke:
