Made a start on one of the cylinder castings today. It seems likely that these castings were made originally for a larger engine, as the dimensions are quite "excessive" in every direction. That's not a problem, but there's that much more material to machine away and thus more time. I first machined the steam chest and frame faces flat and square to each other in order for to of the jaws on the lathe chuck to have full contact. I then machined one of the ends flat in order to set square to the face of the chuck.
My largest boring bar can only go 4.25" deep, and the casting was about 4.6" in length. So it was necessary to mill both ends down until the length was about 4.1". The final length is 3-7/8, so there's a lot to be removed.
Then it was time to mount in the 4-jaw and center on the bore in the casting. It's not necessary to be to super-exact as the cast bore is somewhat irregular and there's lots of material available to adjust to the centerline once bored. I got it aligned to within 1/8" all around.
Luckily my chuck has a 2" center hole, so I could bore out to the target 1.75" diameter without worrying about boring into the chuck body. After multiple slow passes I crept up to the target diameter.
The casting is quite unbalanced, so I needed to keep the RPMs down to about 350 to keep the lathe from shaking. Once bored, I turned outer round surface down to it's target diameter, then faced .25" deep to square the sides of the faces. This is an interrupted cut so I took it quite slow.
Once I removed the casting from the chuck, I stamped the face to identify it as the rear. Since it is as close to square to the bore as possible with the lathe, mounting the rear cover and piston opening there will be preferred.
That's as far as I got today. There's lots of machining to do on these, so it could take a while.
