A small piece of leather worked better than the tape on the copper end plates
I had saved my old worn out Mapp gas torch, so I patched it up and had it in standby in case I needed it for the boiler heads. I have seriously considered the Victor Turbo torch air/acetylene set up because I have two empty B-tanks and a regular acetylene regulator setup. I opted out of changing my plan for the $300, and because I didn't really want to change setups half way through the boiler. So I plodded on heedful of Mike's advice.
Wrapped the boiler in SuperWool ceramic fibre to hold some heat in, and did one end at a time. The end plate, bushings and stay was done in all in one shot rather than separate as others have done. My plumbing experience seemed to insist that it would leak if I heated a joint up in such close proximity to another. Thankfully, everything worked out fine in the end.
View attachment 148310View attachment 148308
It was oxidized pretty heavily, but I had bought some citric acid powder to try out and it cleaned up nicely after soaking for just a few moments. All the joints looked great, so I tested with water and air to 60 psig and let set for 30 minutes. No leaks
There may be a slight interference between the LH tapping and the countershaft. In hindsight I wish I had clocked these two tappings so they were level across the top. The safety valve hex head also has a small interference with the oval slot under the steam dome. Both items are pretty minor to work around and I am very pleased with this milestone in the build.
View attachment 148311View attachment 148309
