I finished the 4 side covers with the Bugatti logo and the circular satin finish , as original engine
In the 2 large covers the logo is directly cast, in the 2 small ones the logo is milled with a 0.5 mm end mill
The processing of circular satin finishing with a rubber wheel mounted on an electrospindle, 7000 rpm and a few drops of WD40 on my CNC milling machine.
To make the fan I used the new printer for liquid resin that arrived a few days ago, this printer does not leave the mark of the layers like filament printers, moreover it is much more defined and precise, the layers thickness is 0.05 mm (0,0019 inc )
This is very useful for making foundry patterns, no need to sand and paint
You can appreciate the difference in the photo of the 2 fans, one made with a filament printer, the other with a resin printer
To put 2 bearings and an oil seal in the drive pulley without increasing the thickness I adopted this solution, the pulley is driven by the crankshaft and a transverse pin.
That is beautiful work, absolutely superb! I've been using a resin 3d printer for mechanical parts (gears, brackets, mounting frames etc). One thing to bear in mind is that most of the resins are very brittle, very much like acrylic. I've used purpose made engineering resins have much better mechanical properties, although they aren't cheap. Here's one supplier that I've used: Formfutura Engineering Resins
The clear type is less brittle, the grey type is very very strong, and heat resistant.
