The casting molds, 3D printed
Awesome work!! got mine running again after the valve job.
Runs better then ever.
Cant´wait to see yours running.
I did my pump from aluminium and glued the two halves together with jb Weld.
Only a small grey seam is visible.
Have you made the pistons yet? do plan to make oil control rings?
I have some smoking with mine and i just used two compression rings and one grove with holes.
Regards Michael
The pipe is made out of several pieces with different diameter joint by soldering. Then the joints where filed/ground down on the lathe.
The piece is almost cylindrical but looks like conical.
The cap is 31mm in external diameter , very important is the distance between the electrodes, not less than 8-9mmWhat diameter is the dizzy cap?
