The brass cast manifolds
manifolds in drilling phase
The blower, I built and milled all the aluminum castings but for now I install it without the rotor bilobe , first I have to start the engine only with the carburetor, without unnecessary complications
The original blower
Cover
2 Bi-lobe rotor
I'd be curious as to how you fabricated and machined the bi-lobe rotor - - - please?
(That is if you are going to create it or have created it! Merci beaucoup!)
Hi PeteHi Foketry,
In my experience of this type of supercharger, i.e. positive displacement, as opposed to a turbine type, it is important that the rotors have very small clearances.
When the rotors become worn, the efficiency of the blower degrades quickly to the point where it takes more power to drive it than is gained from the boost.
If I were making a blower with long rotors like the Bugatti design, I would probably make them in short, manageable sections, keyed to a shaft.
Pete.
Hi SteveIt doesn't take much to spin the blower unless it's making boost. If clearances are real loose it will not make boost and wont steal much power. Of course it would make more sense to leave the case empty if you don't plan to make it fully functional and at least make enough boost to replace the power lost to the blower load.
Hi Pete
I have no experience with blowers, I got information in a workshop near me that restores vintage Bugatti, he told me that there was clearence between rotor-rotor and rotor-casing, over 0,1-0.2mm (0,010 inch)
I saw the disassembled rotors and the finish was not particularly sophisticated
You must consider that we were in 1923-1930 , at that time in the United States the Ford T was built
I found on internet ,months ago, an analysis of clearance and leakage, about bi-lobe blower, analysis speaks of clearance 0.011-0.014 inch
In any case it would be my great happiness if my engine ran ,even without blower
The analysis , a page of 11
Please - - - would like the reference to the article (if possible)?
Re. Supercharger clearances:
The clearance will need to be smaller in a small blower, both in proportion with the rotor diameter and because the smaller blower has a cube law capacity relationship to a larger one and a square law leakage relationship.
So if the blower is simply scaled down 1:2, it will have 1/8 capacity but 1/4 leakage.
A leaky blower will consume almost as much power as a good one. The rotors displace exactly the same volume, but much of the flow is wasted as it leaks back from the hp side to lp.
