I have been doing some lost PLA casting in the last couple years. I use filament called polycast which is designed for this and prints just like PLA, but seems to have similar results to using normal PLA filament, except the fact I can smooth the prints out with isopropyl alcohol. Anyway I think the key to a successful lost PLA casting is good investment material, and having control over the temperature and time of the burnout leading up to the pour. I simply bought a kiln off of craigslist for about 40 bucks and put a programmable ramp and soak timer to control the kiln I bought off of ebay cheap. This process for a part your size will take approximately 6-8hrs I bet, depending on flask size. This helps ensure you have complete burnout, less likely to crack the mold, and correct flask temp when your pouring so the molten metal does not solidify too fast.
The flask size, investment material, and type of metal you are using will determine the temperature and length of time for the burnout, which is not always linear. I think some of my burnout schedules have 8 different steps in them, so you ramp up to certain temps, hold it for a certain amount of time, ramp down, hold it, etc.. All this info will be provided by the investment manufacturer. Ransom and Randolph has investment called plasticast which is specifically designed for lost PLA type casting and I recommend using that.
With all that being said, I still say a prayer everytime I pour because you just never how it will turn out! Lots of trial and error, with even more frustration. Good luck sir!
