b.lindsey said:At the same time I played around with the carb some, applying some moderate suction the the outlet end with the pick up tube immersed in water. This was done with the choke both closed off and open. To my great surprise in both cases water was sucked into and through the carb with a noticable difference between the open and closed choke positions. How this will translate based on the vacuum generated by the intake stroke of the piston remains to be seen, but it still seems to be a good sign for the moment.
Bill
b.lindsey said:and with an even greater respect for the B&S engineers who designed this visually "simple" engine with all its hidden complexities in the days when drafting boards and pen and ink ruled and when CAD referred only to someone with less than gentlemanly tendencies.
Deanofid said:Even more amazing, the same kind of fellows designed things like the P51 Mustang using the same pen and ink, and they did it in a matter of months.
Glad you got your unforeseen problem figured out, Bill!
