Brian Builds the Kerzel Hit and Miss I.C.
Thanks firebird.--Perhaps you or someome else can tell me--I have read on a post somewhere on this forum of a way to treat brass which will prevent silver solder from sticking to it. Its was something really simple that people used, but I can't remember what it was. I want to build up the side of the rocker arm without getting a ton of silver solder migrating to areas where I don't want it.
Wite-out, not the water based muck, but the proper spirit based one - you can still get it, I bought a two-pack just the other day.
:( nowhere near as rapidly as yours mate, I have got the bearing bases and caps fitted, but not bored yet, and the caps still have to be shaped.
Thats a pretty interesting rocker arm Brian. I can see there is a lot of work In that little part. Everything is looking real good, and your coming along very quickly. I cant wait to see all the little "Hit and Miss" parts. Those should be interesting.
Kel
Oh ya, What's the skinny on the two piece spark plug? I cant figure it out.
KCmillin---The sparkplug is being made to plans posted by Kerzel---there is a link to his drawings in my very first post in this thread. I have redone everything in 3D to clarify it for myself, and this is what it looks like. PatJ---I don't like it when it gets this small either. That rocker arm is right on the very ragged end of how small I can work.---Brian
Okay---we gave the "Wite-Out" a try. Actually, it seems to work quite well. If you play the torch flame directly on it, it burns away, but in the areas just outside the torch flame, it seems quite effective in stopping the flow of silver solder. First pic shows the part set up in the vice, with everything coated in Wite out that I didn't want soldered. Pic #2 shows the solder in place, pic #3 shows the finished rocker arm with the excess silver solder filed away.--I think the operation went well. now my rocker arm is cenbtered on the push-rod.
Nice recovery, Brian. Looks like you intended it that way from the start!
Chuck
Hows that saying go, Chuck?---"If you can't be good, be innovative!!!" I think it looks better now than it would have if I had machined it correctly in the first place! ;D ;D
This little engine is taking over my life----Today I started the day by making the "Dog" that the "miss lever" engages with to hold the exhaust valve open. Of course the trick was to get everything to slide properly when its all put together without binding. On assembling all the parts, I found that the hole through the brass bit that the push-rod slides in was about .015" too close to the aluminum frame of the engine, thus putting a severe bind on the pushrod. After determining this by the old "cardbaord cereal box shim under the brass bit" trick, I cut a shim out of some brass .015" shim stock and Loctited it to the underside of the brass guide. While the loctite was setting up, I made the cam shaft stub that the cam gear and cam rotate on. After some esoteric exercises to determine what center to center distance would work with my gears, I drilled a hole in the engine side frame closest to the governor side flywheel and mounted the new camshaft stub, and installed the large cam gear. Then with much filing, sanding, and muttered incantations, I assembled the push-rod and guide and "Dog" and got everything sliding properly.---and that has pretty well eaten my Saturday!!! Wife is sick in bed with a cold and the weather outside is cold, wet, and dreadfull, so I didn't give up too much to work in my comfortable little shop.---And Oh Yes---The hole I drilled for the cam stub seems to be in the right spot. When I turn the engine over by hand, the gears mesh okay. There is one "sticky" spot, but I'm certain it will wear in rather quickly, as the gears are made from brass.
The saying that comes to my mind is, "If you can't be handsome, at least be handy!". Think that's from the Red Greene show.
Chuck
Tomorrow I am going to make the cam. Kerzel made his from brass, and that does not feel quite "right" to me. Brass is soft, and the cam follower bearing running on it will quickly wear a groove---I think. However, the cam rotates on a steel stationary shaft, so if I make it from steel it will have to have a bushing made for it. I have never made a cam using the method Kerzel outlines in his plans, but it seems like a very novel approach. I will make the cam from brass and then see how it holds up. Perhaps it will be fine. If not, I can always make one fro steel and put a bushing in it at a later date, if required.---Brian
It's really starting to look the part now Brian. I assume the box shape above the cylinder is for water cooling. How does this work? Is it just an evaporative system?
Steve
Not far off now Brian, seems like you've got the bit between your teeth and on the home straight. :bow:
Nick
also drilled and tapped the hub on the small gear with four #4-40 threads at 90 degrees.
Lose two of those screws - just put in 2 at 90° - if you install opposing screws to you lose an incredible amount of 'grip' between the gear and shaft. BTW, the second (large) gear should not need any, it should freewheel on its pinion.
SWilliams---Yes, it is an evaporative system. Nick---Yes, its coming along. Tel--In Kerzels plans, the large gear has no setscrews, but is pinned to the cam, and yes, it does freewheel. I didn't know that bit about opposing setscrews not gripping as well---thanks.
The method has been around sence the late 30's - early 40's. I used it to make the cam for the V4 and it works great. I used a small diamond file to round over the nose of the lobe. If you go with 5 degrees per cut you will be able to polish out the flats very quickly with sand paper. It seems like a pain for one lobe but for 4, 8 ,16 lobes it really works great.
Well, I tried Kerzels method of cam grinding, and like my friend Shania says "That don't impress me much!!!!". For one thing, you can rotate the cam to what you believe to be 5 degrees, but when you go to tighten the bolt up, it grips the cam and rotates it to God knows where. I spent half an hour trying to adjust it to at least give me something that resembled a cam, then said #@%! and took it off the fixture, glued it to a 1/4" arbor, and eyeballed it on my 1" belt sander. I did end up with a cam which I'm sure will work. It only vaguely resembles the dimensions on Kerzels drawing, but it has a total lift of 0.074". Kerzels drawing shows a total lift of .061" I'm sure these little one lung engines don't care all that much, as long as the valve opens and closes at the correct time.
Brian. Your project is moving right along.
I don't know if this will help you any, but the few cams I made turned out well using my spin fixture (Spindex clone) to make the cuts, and blended them with a little careful filing. If I remember correctly I used a bevel protractor to check my progress. Can you adjust the lift with the push rod?
-MB
