Cylinder Sleeve Design
Kosiba
Active Member
Chicago
I Just started watching this youtube series of a guy making a motorcycle engine from castings, and when he started machining the cylinder sleeves he had cut a small relief into the sleeve, and then I went to look on one of my 2 stroke nitro sleeves and saw that there was one there too, and now I'm left wondering what they're for and how would you go about actually designing different cylinder sleeves? Like how could/should you position the holes on a 2 stroke sleeve, or what does that relief actually do?
The relief would be right below the lip at the top, this one doesn't have it
And this on does have it
All help understanding this would be greatly appreciated!
The name of the book was "Tuning for Speed", by P.E. Irving, Temple Press Books, London, 1960.
First Ed. 1948.
The two stroke information is a bit dated, and mentions a rotary valve.
The modern two-stroke motorcycle engines use valves in a cage just downstream of the carburetor.
There is some port information, so it may be useful.
Better than nothing for sure.
The 4-stroke information in this book is very good.
First Ed. 1948.
Thank you very much! I'll try to get my hands on it asap!
I've not looked at the video but if he is using insert tooling that all has a radius to the tip of the tool to some extent. If you were to drop that liner into a cylinder that had a square external corner then it would not seat down correctly. The groove give sclearance though the external corner of teh block should also be at least deburred or slightly chamfered.
As drawn your one has completely square internal corners which can become stree risers, if teh parting tool used to cut teh relief has rounded corners then you will get a stronger liner, the common GTN type parting inserts have these rounded corners.
Myself I use an insert with small 0.2mm tip radius and ease the cylinder block so no need for an undercut on engines that I build.
You will also see the relief groove being used for threaded components with a shoulder as you can't easily thread right upto the shoulder.
There's a lot to two stroke design. I've written several series of articles on high performance ones. It would help to know exactly what type of engine you want to build. Below is a history of model, high performance two strokes.
Lohring Miller
  • The Nitro Engine.pdf
    1.2 MB
Lohring Miller
Read it through and I don't quite understand most of the terms used when referring to the bypasses, but it definitely made me quite a bit more interested, and I now have questions about why most modern or relatively modern 2 stroke engines don't use any sort of piston ring?
So these reliefs are mainly just for clearance for sliding the sleeves into the block?
So you are interested in building a model size, high performance, glow ignition two stroke? That's what that article is the history of. Friction outweighs nearly everything else as engines get smaller. A very long time ago I had a conversation with Glen Dye who said the most important factor in a racing engine was the piston to sleeve fit. The other articles in the series explain the procedures needed to build these very high performance engines and some modern examples.
Lohring Miller
I a
Lohring Miller
I'm currently trying my hand and just designing a bunch of engines, and then posting them and getting feedback, so I asked this question because I'm trying my hand at designing a 2 stroke cross plane inline 4 and was curious as to how to design a basic cylinder sleeve and way they are designed the way they are, so I can design a basic sleeve, that will give basic power results.
I have a small model airplane book that has drawings on making patterns and casting engines
Several formulas are in it
One states something to the effect of too little clearance, or too tight a fit o cast linee o luminum fined cylinder either caused too much heating or ran too cold.
I also note, like a piston is made slightly smaller at the top, because heat expands it.
Maybe the relief keeps mass down, which stores heat and causes expansion? Grove=less heating?
Note when making castings, a line deeply scribed in a pattern, makes a chill line in a casting, and castings break there easier.
To an extent, a line scribed in any cast iron is like cutting glaas, it breaks where the line is.
Is this just on cast metal, because the guy I was watching make the cylinder sleeve, had machined the sleeve from bar stock, does it work the same way? Because it was cast iron but it was machined down and he cut the groove and called it a relief groove.
Most people make sleeves of hydraulic cylinders like this. Steel and aluminum expand the same, but at different temperatures.
If he called it a relief, then that is your answer.
The depiction looks excessive. I usually make a very small groove and usually would rather make an inside radias, and chamfer the block. But I do cast sleeves inside cast or brass blocks and usually pin instead of retained by a head like a model airplane engine .
