Disaster averted. I still had the ½ stock in the lathe and the Y axis on the Mill was still locked so it was a quick recovery for my broken part and it fits just as nicely as the first one.
The reason for the ring around some of the pictures is that my camera doesnt handle close-ups very well. This is my Rube Goldberg setup for extreme close ups.
For the rocker arm itself I know the basic size it has to be, so Im purely winging it as to the final shape. I inserted a .125 stainless steel ball where it contacts the valve rod and just trimmed the angles until it looked right
I'm starting to get antsy. For the valve rod guide I just worked from a quick penile sketch and whittled it out of some ½ by ¼ brass. Ill say it again I love those Sowa Spiral Taps
All of my engines up to now, have been made by following known working plans, drawn up by people that knew what they were doing. Any changes I made where cosmetic at best. Ive been feeling apprehensive on this one ever since I decided go swap the cylinder head and valve assembly. Normally Im a pretty patent guy. But normally I dont deviate this far afield from the plans. I partially assembled most of the bits and pieces Ive finished so far. The sliding cam and actuator are held in place by the governor spring, a washer and a plastic cable tie. Its dripping with run in oil and the flywheel needs to be trued up but .scratch.gif
ITS ALIVE! Ok. Im going to try and post a video. The quality is not very good. I just used my digital camera. This might be the first Chuck Fellows Horizontal Single with a Liney Halo designed Valve I still have work to do, but now I know Im not just working on a paper weight.
Posting a movie on Photobucket Go to www.photobucket.com and open a free account. Make a movie with your video camera---it will save it as an mp4 file Download the mp4 file to somewhere on your computer that you can find it. Name it if you want to. Find it on your computer. Dont open it. Right click on it and choose copy Open windows Live Movie Maker and right click once in the rectangular black area, then right click on the clipboard at the top of the screen that says paste---Your movie will appear as a number of still shots, but not run. In top left corner of Windows Live Movie Maker there is a white thing with writing on it that looks like a book with a white triangle beside it. Click on the white triangle, and a number of options will appear. As soon as you put your cursor over save Movie it will give a bunch of options. Choose Windows Phone Small----This will open a new screen with an area coloured blue that says My Movie.WMV---Start typing in a new name for your movie while the blue is still hi-lighted and the text will change to whatever you want to call it. My Sawmill works. Up at the top of the page select what directory you want the movie to appear in and it will save as a .wmv file, which Photobucket can upload. When you go to close down Windows Live Movie Maker it will ask if you want to save your movie. Say No---Youve already saved it. Open your Photobucket account, choose upload, and guide it to where your My Sawmill .wmv is filed. When your movie is finished uploading (it takes a while). Click in the box that says IMG code the box should turn yellow and tell you it has been copied. Go to the forum, start a post, hold down Ctrl on the keyboard with your left hand and press the v on your keyboard one time. There---You have posted a link that others can click on to see your video.----Brian Rupnow
ok brian I don't have enough brain cells to comprehend what you sead much less how you done it . I only have one brain cell left and I don't want to tax it to much I stll have to breathe and some times I think that is to much:big::big::big:
Brian. good on ya! Thm: This is Definitely one of those Copy / Paste / Save for future reference moments. In Photo Bucket I think was picking up the HTML Embed link from the Albums page not the page with the IMG link. I didnt have to change the format.
Cant remember the last time I spent this much time in the shop. Its ok. I have a note from my wife that says this January I can spend as much time in the dungeon as I want. But I think I get to paint the kitchen as soon as Im done. She brings me food and is making sure I stay hydrated. The Backing Plate. Like Brian in his build log I went for milling it out one piece rather than soldering it up. Used aluminum instead of brass mainly because its what I had. Got the blank down to size in the lathe and marked center with a ½ parallel. Brought it down 0.2 leaving the 3/16 ridge down the middle for the weight arms hinge points.
There is nothing like a 1/16 end mill to help me relax. I can hear that little ping as it snaps already. Light cuts, lots of oil and keeping it clean of buildup seem to be the best way to use these little guys. Used the end mill to spot the locations for the two 4-40 screws
With a 1/16 slot and a 1/16 blade on my square setting it up to finish the slots went quick. Once again Light cuts, lots of oil and keeping it clean of buildup did the trick and no ping.
